Hello
iam planning to purchase steam silencer to install it on the warm up line of steam turbine
The current arrangement is there is a manual gate valve (1.5 ") at the steam turbine body which directs the steam to atmosphere to warm up the turbine
The Manual gate valve is opened gradually till reach around 5 ton/hr of steam to warm up the turbine
pressure before the manual valve = 40 bar g
Temperature before the manual valve = 440 C
Maximum Flow = 10 ton/hr
i got an offer from a silencer manufacture offersing a silencer with an inlet pressure 25 barg
and he replied with the following :
During discharge of downstream valve, the pressure inside of silencer’s diffuser will be never exceed 25 barg. Gas pressure release phenomena will be observed during discharge to atmosphere.
So I need to understand how to calculate the pressure after the manual valve to confirm acceptance of this silencer , because i have another two offers offering silencers with a design pressure 40 bar
your help is needed
your help is needed
