Gus14
- Mar 21, 2020
- 194
I am designing a steel beam bearing connection on 20X50 cm columns, the beam reaction is 140 kn. similar to the attached sketch.
Following the AISC manual section J8, the 50 cm length of the column provides an adequate bearing strength. but I have the following questions,
1. Page 2-17 in the AISC manual requires anchor bolts with bearing connection, how to specify how many?
2. In general, If web crippling at the support is not a problem do you see a need to provide a stiffener?
