JT-1995
- Sep 26, 2022
- 36
I am working on a design that requires a steel frame to span between the faces of two concrete walls. I would like to simply detail an end plate connection at the ends of the new HSS shape spanning between the walls. I am concerned that any shop inaccuracies with the fabrication or any inaccuracies in the original wall construction may make the tight fit installation difficult, or impossible. I can not measure the face to face dimension of the wall in place because it is under an operating piece of machinery (our project is to replace the machine that is operating now with a new machine). So, I started to consider fabricating the HSS beam/end plate fabrication "short" and then plan on shimming between the end plate and the wall for a tight fit and final bolting. I am not crazy about that idea, but I am worried about "missing by 1/8" and ya might as well have missed by a mile". My second thought was to ship ONE of the end plates loose and then trim the HSS as needed to make the connection and weld that end of the HSS to the face of the loose end plate in the field. Maybe this is best, but I thought I'd ask to see if anyone had any smart ideas for this problem. THANK YOU.
