Steel Beam Cope
Hot Sauce
I have a situation where a steel beam has a square cope instead of having a rounded profile. I know the web is weakened because of this, but I am having trouble finding a reduction coefficient. Does anyone have a reference they can share?
Thank you.
Is the cope on the tension side or the compression side? I don't know where to find a reduction coefficient but, if your cope is on the compression side, I'd be inclined not to worry about it.
HotSauce, you can find tables with those coefficients in AISC Manual Ed.14 in Section 9
I'm not seeing what Heldbaum alluded to. Or, maybe the information there isn't as helpful as he thought it would be.
Section 9 (of the 14th edition manual) has a section on coped beam strength. But, it does't talk about the detailing of that cope at all (i.e. rounded vs square).
It also has a section on Copes, Blocks and Cuts which talks about the preferred method of sequencing the coping cuts. But, it doesn't talk much about the consequences of a poor cut (in terms of loss of capacity), it just talks about a potential notch.
It does give a few suggestions on how to reinforce a coped beam. But, the tables giving the properties of a coped beam, don't really tell how they would be affected by poor coping.
My suggestion would be the following:
If this is a low stress region, it's probably okay.
However, if it makes you uncomfortable, you can reinforce it.
Not something I've done, but I wonder if you guy just grind out a radius in that area to change the nature of the "fracture mechanics" in that area.
Use a coring-type drill bit on a mag-base drill motor to make a rounded oversize hole in the sharp corner.
Dave
Thaidavid
Look at Roarke's for stress concentration formulas.
