Hi guys. I have a steel beam that is loaded with distributed load + concentrated - point loads at the bottom flange.
So in bottom flange there will be stresses from bending of the beam because of distributed load (qd) + thre will be stress perpendicular to that because of point load acting on the edge of a bottom flange. I was thinking about using Von Misses criteria for this. The problem is it has been ages since I have used this. I forgot a lot. is it allrigt to use 'plane' equation for this and Gyy as G1 and Gxx as G2?
