Steel behavior (strain) under hydrostatic pressure past yield
ddlmodes
Petroleum
May 2, 2012
5
Below is my question:
A steel of 200Mpa yield, when loaded to:
Case #1)
Stress1=stress2=stress3=400Mpa
Strain1=strain2=strain3
= 0.1% -0.3*0.1% -0.3*0.1% (Elastic strain)
+ A% -0.5*A% -0.5*A% (Plastic strain = no flow = 0)
= 0.04%
Or 0.08%? (After yield, continue to deform elastically)
Under uniform compression, steel should not yield/fail when loaded past yield value.
But the resulting strain is a bit confusing (I post Case #1 first).
Any idea? Thanks in advance.
Hi desertfox,
Thanks for the lecture link.
I do understand about the point in Mohr circle & non-yielding (for uniform compression).
What I am having doubt is on the strain response.
Will the cube compressed elastically & infinitely as per calculation ie 0.08%
or will it be retarded at 0.04% (strain at yield in this case,
or maybe even later after strain hardening at UTS strain)?
