Steel bracing in sap
hamedthelord
6
is there any way to prevent area from transferring load to roof bracing instead of moving bracing and making joint constrains?
Select the frames and then "Assign -> Frames -> Load Transfer Options...".
Untick the check box and the selected frames shall not be loaded from the areas.
