I am looking at designing repairs for a rusted out steel deck and a hole in the slab above. The location is near high temperature industrial equipment and is exposed to moisture from rain. I am looking at epoxy rebar or a sacrificial zinc anode tied to the rebar and/or deck. The original design only had one layer of rebar, so I suspect the failure occurred because the tension couple was lost when the deck rusted out. I plan on using the deck as a form instead of a composite so that slab failure will not occur if the deck fails, but is there anything I can do to prevent corrosion of the deck beyond standard galvanization?
