Mohamed Maher
- Dec 31, 2017
- 132
Dear all
We have some steel pipes and tubes we bought it from supplier to be s355 grade we make test after receiving the materials and we found some steel sections not achieved the elongation limit..is this can be used? knowing that we design on wind only not seismic as it's not govern
That was the first case
The second case some of items not achieve yield or tensile strength some of them achieve 300 mpa only instead of 355 in the yield and less in the tensile strength as well.
The second case can be checked based on the less limits or should be rejected whatever it's safe or not?
Maher
Maher
