Steel Frame Brace Design
Hercul3s
29
BR
Can anyone tell me the reason for the "fuse region" (space between connections) in an eccentric Inverted "V" Brace? I am pretty sure it allows for deformation of the beam to which they connect, but what is the main advantage of that? Please see file attached. Thanks.
 http://files.engineering.com/getfile.aspx?folder=1aff07ef-ecb5-42cc-99ad-1478c41c2af2&file=image_large1.jpg
The fuse region provides a location in the brace that will deform inelastically and absorb energy to provide a better type of brace in high seismic regions....verses a more brittle brace system in the other types shown on your attachment (like a concentric X brace).
faq731-376
An eccentrically braced frame (EBF) has the advantage of combining the stiffness of a braced frame system with the ductility and energy dissipation of a moment frame. Thus getting the a better response modification factor
Excellent - Got it!
Any hint on how to calculate or dimension of the fuse region? Is the "beam depth" a rule-of-thumb to follow?
