Steel Gas Piping
eatapeach
Military
I read in a code but do not remember where but when two or more black steel pipes are installed at the same location, the gas pipe is required to be identified with yellow stripping or painted yellow.
Does anyone know where this may have come from? I am in Texas, and I have looked in the 2021 IFGC and the NFPA Gas Code but did not see this verbiage. I know I read this, and it does make sense if you have sprinkler pipe and gas pipe installed next to each other, the gas would require to be labeled.
Think it's just a good idea so you don't cut into the wrong pipe.
The 4” gas line is upstream from the meter and is installed overhead for a cooling tower.
The code that I read did state the reason is so someone doesn’t mistaken it for something else. I just do not remember where this was called out
I have seen client specs that mandate piping identification schemes.
Mike
