JAE
- Jun 27, 2000
- 15,556
I think most engineers, when using an open steel joist, will have on their plans a typical detail that calls out a steel angle to be added to the side of the joist when a concentrated load is applied either to the top or bottom chords - but - away from a joist panel point.
Over the years we've generally used a detail that says the following:
Use the extra angle if the concentrated load is BOTH over 150 lbs. and more than 4 inches away from a panel point.
I've searched all over the SJI site and the Vulcraft site and cannot find any justification for these two numbers (4" and 150 lbs.). I've also seen 6" and 500 lbs.
Anyone know a source document, website, etc. that actually attempts to dictate the source of these numbers - or what they actuall can or should be?
