strucbells
What are the advantages of using steel lintels over door and window openings for masonry walled buildings? I see questions on here often about these.
I mainly do industrial and water/wastewater projects and we often design small to mid size 1 story reinforced CMU pump station/etc. buildings and we typically specify CMU lintels built up within the wall, even for decently large spans over 10'-16' wide roll up doors, we usually can get the depth we need to make it work, especially if arching action can be taken advantage of.
This seems simpler to coordinate and install.
Are there advantages on commercial buildings or for multistory projects or in other sectors that make steel lintels advantageous?
