Steel Perpendicular Connection
francis_intano
17
Does anybody know what this type of connections are called? Any references on how to design them?
I have a pretty much same structure to design, so I was thinking maybe I could do this scheme too. Any one who has an idea?
If you have to ask then you shouldn't be asking.
This applies whether you are a student (this forum isn't for student projects) or an engineer.
It's a heavy welded node on top of a concrete pedestal. This is likely a bridge application, where a specific firm will have designed it, in coordination with a fabricator, to a very specific set of loads/codes/requirements. Those huge stiffeners and bearing elements are there for a reason, perhaps seismic.
I don't know the reason, but you definitely need to know why. Start asking questions to your offline peers/leaders first, because a generalized answer from the internet can only take you so far with such a complex arrangement of specialized conditions, heavy welds, and stub beams. For instance, your geographic location alone could validate/invalidate the applicability of anyone's response from this site.
@ francis
connection between Steel and Concrete
attached file may be helpful
Link
It looks like a steel bearing connection of a bridge steel bridge onto a concrete column.
I'm not really a bridge design guy. But, this connection seems pretty unusual to me. I'd be wary to copy this unless you're getting some advice from an engineer with a lot more bridge design experience.
My guess is that this is NOT the most economical connection / construction. But again, I'm not much of a bridge guy.
Looks like a distribution platform for a bridge bearing carrying a very heavy load, probably in the thousands of kips. Given the small dimensions of the column, I would surmise the bearing it is to support is a sliding bearing or a seismic isolator.
In any case, as others have said, you shouldn't be copying the configuration for a different application. This is obviously designed for a very specific loading scheme.
This looks like a one off design to me, so I doubt you will find a cookbook method to design whatever it is. What is your structure and what is the structure in the photo?
Thanks everyone! On another look, seems like a specialized design for specific project that I might inquire here locally.
