win
- Jul 10, 2013
- 19
Im relatively new to the water world. For a pressurised steel water supply pipeline laid in relatively soft ground, what is the normal approach to minimize differential settlement between the pipes and chambers and anchor/thrust blocks?
Is the option of piling the chambers to a floating length (rather than to set) viable?
I read that rocker pieces are used to allow for settlement but being a pressurised main, it seems to me that the rocker pieces will need to be restrained, will this end up limiting the amount of deflection available?
