1
- #1
I have attached a sketch and calculations for a simple frame which will have a very small impact load applied downward at the mid-span of the beam. The required minimum natural frequency of the structure measured along the vertical axis at the mid-span of the beam is 200 Hz. From the attached calculations, it appears that column deformation alone makes this unattainable. (For simplification, I have not included the applied load in the calculations (200 lbs.) as that would not have an impact on my conclusion). Am I missing something here? Any assistance would be appreciated. Thanks.
