kwinner
- Jul 6, 2020
- 20
Regarding mechanical equipment loading on prefabricated steel roof joists, I am wondering what your experience is with mechanical units being located in their proper locations in the field. Typically, I see units shown on roof plans with dimensions and total load. I ask this because I know the joist manufacturers apply their mechanical loads as point loads in specific locations. As we all know, many times HVAC plans like to change, and contractors aren't as concerned as we are when placing units in their final location. I anticipate chord bending issues if units are not located in the precise location they were designed for. Has anyone experienced issues with this?/How do you deal with this in the design phase?
On my last project, we wanted to build in extra capacity in the roof joists to allow for multiple scenarios in which the mech unit layout has not been completed. We achieved this by applying the mech unit loads as add-loads (which may be placed at any panel point along the length of the joist) and applying the max bend-load along the length of the joist. This gave us a lot of flexibility with mech unit placment in the field, but was very economical and it was difficult to work with the fabricator as it appeared they had not performed this analysis regularly. Is this a common practice?
Kevin
Kevin
