sybie99
- Sep 18, 2009
- 150
Having worked in the UK and now in South Africa, I have noticed a difference in the steel weight engineers design to for steel roof structures. QS's are very strict and will inform a client if an engineer over designs, as they have learnt from experience what tonnage will work for a specific roof structure.
I am talking about steel portal frames spanning between steel columns, or trussed roofs spanning between concrete columns. Of course in the UK there is an allowance for snow loads which explains why in the UK tonnages are heavier.
Here in SA a roof, including purlins (generally cold formed lip channels) should not be more than 20kgs per m2. More like 15 kgs/m2 to keep the client happy. That is a VERY light roof and takes some time to refine, but it is designed to BS5950 code requirements.
Can anyone who designs structures in a warm climate area with no snow loading tell me what they use as a rule for steel tonnage per square meter for steel framed soft roofs?
This is purely for interest sake, as a guideline.
