David B
Specifier/Regulator
- Sep 13, 2019
- 4
I want to make a 90-degree cold bend in a .25” x 3.5” x 17” long 1018 Cold Finish Mild Steel rectangular bar -- 4” from one end. The 13” leg would sit flat and the 4” leg would be vertical. (I could alternately use .25” x 4” x 17” Hot Roll A36 Mild Steel.) My inquiry concerns the steel strength at the 90-degree bend, which had been deformed beyond its modulus of elasticity. I intend to impose a force of 2,000 lbs., evenly distributed, onto a 3.5” x 3.5” x .75” (12.25 sq.in.) High Density Polyethylene (HDPE) block mounted directly to the inside face of the 4” high angle. Would a 2,000-lb. force be sufficient to cause the 90-degree bend in the steel to “flatten out” in any way? I’m guessing there’d be little, if any, deflection at that 90-degree bend, but I’d like to get feedback. Thanks.
