skeletron
- Jan 30, 2019
- 892
I'm designing some 16ft non-loadbearing interior steel-stud walls in an arena. Roof is 42" OWSJ @ 6ft o/c with standard metal deck. The OWSJ span 60ft. The room I'm working in is pretty much mid-span of the roof joists. This is an area that can get up to 50psf snow.
Most of my interior walls run parallel to the joists and will be fit up to the deck. I am spinning my wheels trying to figure out what to do with the deflection gap at the top of wall. I know that the deck will deflect L/240 = 5/16" and the OWSJ is likely also designed for L/240 = 3".
1. Is my design deflection at the deck = 5/16" + 3" since the deck itself will drop relative to the supports. I think it needs to be at least 3" because the OWSJ would drive the roof deflection.
2. Most slotted tracks give up to 2" total deflection (1" up + 1" down), so I'm now seeing recommendations in previous threads (#1 and #2) for top deflection clips or fire-stopping style track that can provide greater deflection values. TDC clips by Bailey and RipTrak by Clark Dietrich have been mentioned and look like they may help. Is this the go-to solution for this type of scenario? I think the clips would be easier to access and seem more conventional.
3. When the "total deflection" is reported on any one of these components it is usually indicative of an equal amount of movement up and down (i.e. Up + Down = Total). Is there a way to squeeze more deflection out of this by installing the screws at the bottom of the slot and utilizing the "total deflection" as my full deflection gap? Am I running a risk that the floor deflects and creates deformation at the top of the wall because the roof hasn't deflected (e.g. summer or fall w/o full roof load).
