I have a 12' dia. steel tank, right circular cylinder with an open top containing water. I want to construct a catwalk across the top and support the catwalk on the edge of the tank. The tank provides a knife edge support for the channel of the catwalk.
The load from the catwalk is relatively small. Is there a simple method of determining the effect of the point load on an unstiffened edge of a tank? The tank is constructed of 5/16 material, likely A36 or something of that ilk.
Dik
Dik
