VojtechBrychta
Automotive
I have encountered an issue and I was wondering whether you can help me with it.
I have a front axle assembly with a steering system trying to run a suspension analysis:steering. The steering consists of a steering wheel that goes to a steering lever through a reduction box. Now, if I set up the reduction at 10 and run an analysis from -100 to 100 degrees, the simulation runs just fine. If I set up the reduction at 1 and run the analysis from -10 to 10deg, the simulation fails pointing out a following error:
Static equilibrium analysis has not been successful.
The maximum number of iterations 25, has been reached.
For the last attempted iteration:
The equation with the largest error was model.testrig.controller_steering Comp = 0 Error = 0.000000
The variable receiving the largest increment was model.testrig.jostra_steering_part Comp = 3 Delta = 9.099849.
This means I try to run the simulation with the same inputs, only difference is the reduction. I checked the pvs_max_steering_torque and angles, and both should be within the limits. I don't see any other inputs that might cause the simulation to fail.
Do you have any tips?
Thanks a lot!
Sincerely,
Vojtech
Thanks a lot!
Sincerely,
Vojtech
