I note that on globe and check valve the use of stellite as hard facing and corrosion resistant layer on trim parts is the best solution for many vendors.
For ball valve I see that a lot of vendor use carbon steel with Electro Nickel Plated as trim material as corrosion and hard facing layer.
Someone knows the reason of this distinction. Which is the main difference beetween this two surface treatment.
