  • Congratulations Toost on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Stellite repair/rework
ArcSpawn
Industrial
Mar 9, 2011
1
I just joined and came across some interesting information regarding stellite. I was just wondering if anyone had any tips for repairing cracked stellite or adding additional stellite to a part that was machined improperly? Its greatly appreciated!!
Check with your local welding consumables supplier. He will be the best to advise you with various options depending on your application.
_____________________________________
"The richer we have become materially, the poorer we have become morally and spiritually." Martin Luther King Jr
In addition to the above response, we have Stellite 6 in various valve applications across our Plants. Stellite 6 is repairable but requires elevated preheat at 500 deg F and weld repairs should be with Stellite 21 over Stellite 6, if possible. Otherwise, your only other option is to completely remove the Stellite and start over.
Stellite is a registered trademark of Stoody Deloro Stellite.
Contact them for info. Many versions of it and usually excellent technical support.
Thomas J. Walz
Carbide Processors, Inc.
Good engineering starts with a Grainger Catalog.
You might try TIG welding Stellite into the cracked region and then remachining it.
Over the years I've been involved with welding quite a bit of Stellite including crack free ( well almost) Stellite 1. I'd suggest you contact Deloro Stellite directly, and I'd start with Brad at 613-968-3481.
