tmox
- Feb 14, 2002
- 82
I can't believe that SW will only allow sketch data as variables for Propery Manager.This wouldn't even be an issue in Inventor as you could sort by ANYTHING.
I have a very large table of Mil-Spec parts. Of those half are readily available from commercial vendors, the others require long lead times. So when i select a component from the property manager i would like one of the variables to be "VENDOR". Since only sketch variables can be used.......can i force a dimension to be text? Something like D1@Sketch1 = "OurSupplier", or is possible to write an equation like, if(d1@sketch1=1,"oursupplier","milpart")?
i have lots of library parts that i would like to sort by something other than a numerical value.
When i talked to our SW rep, they said, "Hey, that would be a good idea...".
No, REALLY?
No, REALLY?
