Stonehenge: Could You Make A Monument For 5000 Years Service?
racookpe1978
Nuclear
Just a question:
Stonehenge began to be built between 2500 and 3000 BC, or about 5000 years ago.
If you were charged with making a memorial to commemorate Stonehenge - with today's materials - so that it would be accurate to the north star, the rise and set of the sun at the solstices, the stars, solar eclipses and lunar eclipses in the year 7100 - 5000 years from now, what would you use to build a similar size and shape monument?
How would you set the foundations and material so they would withstand that long in the open air, but still be accurate to the (future) position of the stars? Granted, many stones at Stonehenge have fallen, and it is very crude model, so you'd have the responsibility of not "re-making" the rough outlines we see now, but (for example) you'd have to carve sharp, accurate edges and making the monument so the "bridges" would not fall.
But how would you do the job? If you pour concrete for the foundation, what would you use as rebar to keep the concrete good that long? Would you make everything of stainless steel? Granite and stainless?
I used to drink at the Royal Oak in Winchester which also claims to be Britains Oldest Bar, the building dating back to Saxon times.
Posting guidelines faq731-376 (probably not aimed specifically at you)
What is Engineering anyway: faq1088-1484
To answer the OP's question, I would build it out of leftovers from my significant other's dinner menu. I'm reasonably certain that everything she cooks would survive tens of thousands of years out in the elements, and would most certainly be left alone by both man and animal alike.
I thought they did a nice job recreating Stonehenge on Spinal Tap.
JMW: It's a safe bet that they'll find a lot of Taco Bell and Chinese take-out during my autopsy...
A great building material would be low fat mayonnaise. I have no idea what it's made from, but it is impervious to the elements and all known cleaning materials.
- Steve
LinkedIn
Imagine what it's doing to your bowels then!
I wonder if, when the scientists and archaeologists get done messing around with Stonehenge and finally figure out the true final design and rebuild it that way, it will suddenly send a signal out into deep space?
Maybe they'd better stop messing with it.
JMW
