StormCAD Newbie
daisem
Hello All,
I am a StormCAD Newbie and am working on a final project for class. I have taken an aerial photo of a residential area I plan to analyze with this program. My question: how can I scale my photo so that when I start adding my conduits, etc., they are roughly the correct length?
Thanks so much,
Daisy
Dear Daisy,
Use Google Earth and draw square with known dimension. This square will help to remeasure dimension after printing/scanning/photocopying like old days drawing scales.
HSiddiqui
Bring it in as an image into AutoCAD, you're going to need to transfer the .dxf file anyway.
As it was said above, you need to find a couple known distance, which you'' need to field verify unless you have a survey. Get some parking stalls, inlet to inlet, building dimensions, etc ... something you can pick up in the aerial, then scale and rotate in CAD
How does one come up with Intensity-Duration-Frequency Curves and Time of Concentration? Is this input manually or can one import (and how)?
100% Lost
Also, I only have academic license so I have to cut the project into parts....
OK! I got the IDF Curve off of the NOAA website (hope that's right). Now, for time......
