CezarAndrei
i want to build a load cell that's using one or more strain gauges connected to a wheatstone bridge. so i was thinking to a beam (12mm X 24mm, 80mm long), fixed to one end and free on the "load" side. the strain gauge will be glued to the bottom of the beam (on the surface of 12X80) (would be a compression cell)
than for a maximum elongation, i'll drill a hole of 18.5mm in diameter on the surface of 24X80 with the center above the gauge,.
any idea of what is the best method to estimate how much the elongation would be based on the force applied at the free end of the beam?
Thank you very much
(sorry for my english)
