Totobolz
- Oct 9, 2019
- 7
Good Day.
To All Strand 7 FEA experts,
I am using Strand 7 to perform Nonlinear Analysis in a Plate Model where I encountered this error:
ERROR[ 13]:Solution has diverged. Rotation at node 7372 (1.9370E+08 deg) is too large.
and this warning.
*WARNING[ 73]:Internal angle is out of range in plate 15137.
*WARNING[ 73]:Internal angle is out of range in plate 14130.
Plate properties are properly defined.
The thing is the DOF/node restraint applied.
I used the fixed restraint with no error but when applying ZX symmetry as restraint. Error occurs.
I also attached the model as reference. Feel free to check.
Thanks in advance.
and this warning.
Thanks in advance.
