Strand 7: Error Solution has diverged. Rotation at node 7372 (1.9370E+08 deg) is too large. 2
Totobolz
PH
Good Day.
To All Strand 7 FEA experts,
I am using Strand 7 to perform Nonlinear Analysis in a Plate Model where I encountered this error:
ERROR[ 13]:Solution has diverged. Rotation at node 7372 (1.9370E+08 deg) is too large.
and this warning.
*WARNING[ 73]:Internal angle is out of range in plate 15137.
*WARNING[ 73]:Internal angle is out of range in plate 14130.
Plate properties are properly defined.
The thing is the DOF/node restraint applied.
I used the fixed restraint with no error but when applying ZX symmetry as restraint. Error occurs.
I also attached the model as reference. Feel free to check.
Thanks in advance.
 https://files.engineering.com/getfile.aspx?folder=331d45d9-0fc2-4928-837f-2730c0939282&file=Chute4.st7
Could you attach a picture showing your model with boundary conditions ? I think that it’s underconstrained and thus rigid body motions occur.
Based on what FEA_way mentioned,
run an analysis for Eigenmodes. If there are any with 0.0 Hz frequency you have rigid body modes.
Another thought, does nonlinear analysis i Strand automatically include large deformations?
Thomas
Totobolz.[ ] Do you get a similar sort of problem if you perform a simple linear analysis on your model?
ThomasH.[ ] I haven't used Strand7 for quite a while, but when I last used it the inclusion / non-inclusion of large deformations was optional.[ ] I think the default was non-inclusion.
@Denial, linear analysis worked fine.
Okay, I'll check the settings for the large deformations.
Only a few people here are Strand7 users, so it's always a good idea to post some images so others can comment.
You have your nodes restrained in the Y direction only, but gravity is in the Z direction.
I'm surprised the linear analysis completed, but if you look at the log file you will see the deflections are a little on the large side (about 1E10).
If you want symmetry about the XZ plane then the nodes on the plane of symmetry need to be fixed in the Y direction, but you also need to restrain global movement in the X and Z directions.
Doug Jenkins
Interactive Design Services
@IDS, thanks for passing by. I read many of your replies.
I tried the "automatic sub-incrementation" of Strand 7 particularly the Displacement scaling and Displacement Control.
The solver proceeded but the iterations were painful. more than 50(about 15mins before I stopped it).
I agree with what you said about the ZX symmetry restrain.
 https://files.engineering.com/getfile.aspx?folder=7f415e3c-ab28-4e07-948d-91b52efd4af6&file=Capture.PNG
Just a suggestion if a non-linear analysis is giving problems: set the first iteration load factor to a very low value (say 0.01). If that fails to converge there must be a problem with the model, other than non-linear behaviour effects. In this case the analysis failed at the first iteration, suggesting there was a problem with the restraints.
Doug Jenkins
Your model is not adequately restrained. I ran a Linear Static Solver (ALWAYS a good place to start!), and the solver log file gives the following displacements.
Results for 1 Load Case...
MAXIMUM DISPLACEMENT MAGNITUDES
Case DX DY DZ RX RY RZ Name
1 9.45004E+10 1.23440E-01 1.27770E+11 2.46870E-03 1.98140E+07 5.19257E-04 "Load Case 1"
You have not applied any X-displacement or Z-displacement restraint in your model. Fix this, then run a Linear Static solver (to validate overall model behaviour etc), and then and only then, start looking at non-linear static, buckling modes, natural frequencies, etc.
