1
- #1
geotechguy1
- Oct 23, 2009
- 671
I'm not sure about other branches of engineering, but for 10 years I've fairly regularly encountered people who behave as follows:
1. We assess consolidation parameters for a site, say using one dimensional consolidation tests
2. We use some simple empirical correlation between SPT - N values and some parameter
3. We make a simple calculation using a closed form solution for bearing capacity
4. We make a calculation of stress distribution with depth caused by an imposed load
Essentially, never offering an alternative or solution, just throwing shade on anything and everything. Usually it's a PHD or MSC without much practical experience or alternatively just someone trying to do what I assume is assert themselves as a technical expert. I had a crack at it behaving like these people for 6 months once and I can't see the benefit of doing it.
"Uh uh uh, sample disturbance, the standard push tube diameter is to small to be accurate, etc. Can't use those parameters
"Uh uh uh, have you applied these 300 corrections to SPT, and it's unreliable anyway, can't use those parameters
"Uh uh uh, here's random reason y we can't use the Terzhagi equation
"Uh uh uh, you can't use bousinesq, westergaard, 1H:2V, soil isn't an elastic medium
