Strength of Materials Review Problem
LFRIII
Going back to strength of materials book to refresh after many years. Working through problems. Looking for help solving the following problem:
2. A cantilever beam is composed of two 6x6-in timbers held together by bolts and connector rings. The beam is 3 1/2 feet long as has a concentrated load applied at the end. The bolt holes are 3/4" in diameter and each connector ring can safely transmit a force of 6000 lb. in shear. If the load P=5000 lb., what is the required spacing of the bolts? Answer e=9.6 in.
Got that one. Next one is the mystery
3. Calculate the maximum bending stress in the beam of the preceding problem assuming that the first bolt on the left is 2 in. from the left wall. Answer sigma = 1590 psi.
Any assistance would be appreciated.
Q2 can be solved by VQ/I; Q3 is simply My/I (assuming the beam is fully composite).
Are we assuming 6"x6" is the actual dimension of the beams? If so, the numbers for Q3 are close but not 1590psi. But to take them as a more realistic 5.5"x5.5", it's even worse.
What is the significance of the first bolt being 2" from the wall? Does that enter into the calculation?
BA
Critical bending stress would be based on a reduced cross section where the 3/4" hole is deducted from the gross 12"D x6"W section.
Itotal = 123*6/12 = 864 in4
So Inett = 123*(6-0.75)/12 = 756 in4
y = 6"
Maximum moment at face of cantilever: 5 kips * 42" = 210 k.in ==> σ = 210 k.in * 6 / 864 = 1458 psi on total section
Moment at first bolt hole: 5 kips *40" = 200 k.in ==> σ = 200 k.in * 6 / 756 = 1587 psi <== GOVERNS
Okay, hadn't thought about doing that, but I agree with Ingenuity.
BA
