Hello everyone,
Hope you are all enjoying the warm weather for everyone living up north!
I have a project where the client wants to add a hot tub and additional dead load onto a flat roof. Because of this the current W530x74 beams are not sufficient (fail by moment). it is not practical in this circumstance to add additional beams or posts, so I was looking on what can be done to strengthen the current beam since the fail ratio for moment is about 1.15. The scenario that seems to work based on SAP modelling is to weld a 3/8" plate to the bottom flange through the entire length.
My question however is does the plate need to be continuous or can you weld it in 3 piece lengths ? The steel beam is over 36' long! I'm having trouble modelling this. Anyone have experience doing this ? Would welding it in 3 pieces be an issue ?
Thanks again!
Thanks again!
