rittz
- Dec 30, 2007
- 200
Two steel plates 12" x 12" x 0.75" are welded to a third plate 12" x 28" x 0.75" such that they essentially form the shape of a WF beam 28" deep 12" long with 12" flanges. The bottom flange is welded or bolted to a structure below. An axial horizontal load is applied to the end of the top flange and web. How would you calculate the max tension and shear stress in the plates.
