Stresses in a very wide T shape
r.borghino
10
I am working on a problem where I have a roughly "T" shape profile (inverted) where I am applying two equal point loads to the top of the single leg. I am trying to evaluate stresses on the flat plate caused by the cantilever leg. I usually simplify this problem and simply assume a flat plate with a moment applied at midspan. However, I'd like to make a more "real" analysis without going into FEM. I've looked through Roark and other sources but to no avail. I am definitely missing something... do you have any help or insights to spare? (is it even worth the effort?) Thanks! T Profile.jpg
The best approach will depend on:
1) What specifically you would like to achieve as a design goal and;
2) What aspects of behavior your are willing to consider trivial.
An effective length as shown below would appeal to me assuming that the dominant concern is warping torsion.
What sort of force magnitudes are we talking here? Depending on the load there might be some simplifications that you can make without losing too much sleep on it. Otherwise FEA is the way to go.
Here's a quick model with F1=F2=1kN just to illustrate what kind of stress distribtion you'd expect; this is in line with what KootK has shown above.
What I'm seeing is that the web of the T is getting a stress concentration on the end which could suggest some form of buckling, long before the load fails towards the middle of the plate.
Thanks for that, I realized I over-simplified the analysis a bit (one of the edges of the bottom plate is continuously braced, the other end is free). I add an improved sketch.
Deflection is not a concern. The design objective is to avoid local yielding at the point where the leg meets the plate.
Roughly 1-1.3 kips. Loads are relatively low, but the shape is pretty slender too. This one is thicker than usual at 1/4". Other T shapes I've worked with are 1/8".
Adding the supports to the braced backside helps unload the flanges a bit but you still get that same stress concentration on the web "T". Take it with a grain of salt, but with your loads in and modeled as 1/4" thick the maximum stress in my FEA is exceeding your typical 44W steel.
Are you sure that you need to avoid "hot spot" local yielding? In many situations, I would be willing to let the stem yield locally and redistribute.
Performed a quick FEA and yes, same results. Using the usual approach with the moment at center of beam gives me a much higher stress at the plate.
I'll think about that. This is a curtain wall application. Usually anything that yields would not pass muster because any small permanent deformations can compromise the water management. The load is a wind load reaction so it needs to receive that point load acting alternately in both directions repeatedly throughout the service life (admittedly in much lower intensities).
So if I understood correctly your approach would be to calculate or estimate an "effective length"?
Your shape likely will buckle under load.
Read about members in bending. In this case you need to check for buckling since it is essentially a plate unbraced. Add gussets to strengthen the section at the loads.
