haideeb
- Nov 28, 2018
- 10
A method of calculating the required strength of concrete to strike the slab formwork as described in CIRIA 136 is by taking the ratio of the slab selfweight + construction loads to the design loads in comparison with the design concrete strength. I am however dealing with thick transfer slabs 600 to 1200mm in which I really can't get a ratio based on design loads as they are not uniform, what would be the more appropriate way to calculate the concrete strengths required to strike the formwork?
