Christian_S
- Oct 31, 2022
- 23
Hey
I'm not a structural engineer, so excuse my ignorance on the topic. We have some pipe support shoes that are to be attached to pipes that are 300 degrees Celsius. We had a material engineer who said it was okay to use 316L Stainless steel at these temperatures, but the person doing the structural analysis of these shoes was a bit unsure how to proceed as there were no guidelines in Eurocode 3 about analyzing at high temperatures. I wonder if the exclusion of this topic might mean that it's not relevant as long as you use the material properties for the temperature in your environment.
Would it be okay to proceed with the material as long as we consider the yield and tensile strength at the temperature given?
Tensile table for some 316L alloys attached, as you can see they have defined properties up to at least 350 deg Celsius.
