greencircle
- Nov 19, 2014
- 88
All,
I need help from you guys to recognize few steps from the below calculation for a lighting post. Unfortunately I have no drawing, but quite simple to visualize.
I am clear that the [highlight #729FCF]blue color[/highlight] highlighted are need to be updated to current values. The gust multiplier of 1.32 is outdated & believe I will have to use 1.14
The Wind pressure formula also should be modified I believe.
I don't understand the [highlight #F57900]orange color[/highlight] highlighted area. I would appreciate if any one of you help me identify these values/formula used.
[ol 1]
[li]In the formula for FP, I don't follow why its 4/12. I think this is got to do with the conversion of in to feet. But not sure what & why?[/li]
[li]Similarly in the FB calculation also. what's 12 + 6, where did these come from? I can see 12 is the height of the pole; but whats 6 for?[/li]
[li]Under "To Check Anchor Bolts"; whats the 36 for? I guess its KSI value of steel AB? But I am not sure. But I dont understand whats the 1.4 for?[/li]
[li]Then under calulation for T, whats the purpose of multiplying with 0.012[/li]
[li]To check Base Floor : What is M? I can see that M is calulated by ARM x T[/li]
[li]The next one is the calulation for S. It appears, it's a calculation of section modulus. then why /6?[/li]
[/ol]
Thanks,
GC
[ol 1]
[/ol]
Thanks,
GC
