RobertHale
My firm was acquired by a larger firm in the past year, and we are now undertaking the task of unifying the way we do business. One of those items that have come up is our role in defining special inspection requirements and the required code documents. My old firm had a fairly robust set of documents but they effectively forced us to define the requirements for non-structural items. This seemed to be okay within the geographic area we did most of our work in. Now that we are part of the larger firm, the area of our work is much broader. I am interested in an informal survey of some pretty basic information.
[ol 1]
[li]What has been your role in generating the Schedule of Special Inspection? Do you only define the structural special inspection items, or are you defining all the special inspection items when you work on the Schedule?[/li]
[li]What has been your role in generating the Statment of Special Inspection? Do you always create it? What party is typically the Registered Design Professional In Responsible Charge?[/li]
[li]What is your role in the Seismic/Wind Requirements, and do you generate forms for these?[/li]
[li]What do you typically put on the drawings, and what do you put in the project manual? Do you generate any specification sections or additional documents that stand outside the typical Construction documents?[/li]
[li]Do you ever work with institutional/government owners that upset the typical scheme where the owner selects/pays the special inspector, and the reports are submitted to the building official as well as the design team?[/li]
[li]Do you use forms and documents created inside your office or are they generated by an industry org or an NGO? Also, do you use forms generated for one jurisdiction inside other jurisdictions?[/li]
[li]What jurisdiction do you do the majority of your work in?[/li]
[/ol]
I realize I may be a "country mouse" in the big city, but I want to try and get as much information as I can and understand how this process works in different parts of the country. I want to make meaningful input to the discussion. And i need more data points to come to a reasoned position.
[ol 1]
[/ol]
