hsustersic
Looking into the maximum length of a building before having to add an expansion joint. It looks like concrete and steel structures are very well-defined in this regard by AISC 360, Tech Report 65, and ACI 2243r-95/01, but I do not see equally clear references for bearing wall structures. The BIA Tek note 18-A appears to apply to brick veneer rather than load bearing CMU.
What is the recommended spacing of structural expansion joints in buildings constructed with:
CMU bearing walls
Cold formed metal bearing walls
Any thoughts?
Thanks.
CMU bearing walls
Any thoughts?
Thanks.
