I have a daylight basement slab on grade to pour. The existing soils are compacted. I need to add about 8" of sand, gravel, ?, to reach sub-grade for my slab. Also, I have radiant tubing in the slab so will need to add insulation board. I am being told to go 4" of 5/8" gravel compacted, 4" pea gravel, 6 mil vapor barrier, 2" insul board, and topped with wire mesh. (My radiant flooring sub wants the wire mesh) My main concern is the drying of the slab. My concrete sub says that without sand or some other "absorbing" material below the concrete, the slab will only cure from above. (uneven curing) He suggests 4" of 5/8" compacted gravel, 2" insulation board, vapor barrier, 4" sand, then wire mesh. I should also mention that I have intermittent footings on the interior of the building so this makeup is "broken" at these locations. Is it ok to pour 4" directly over the top of these footings without a capillary break or insulation?
