Structural Frame Analysis
Da CnS Engr
MY
Hi everyone,
Attached is photo of a structural frame. Can anyone help to resolve R1, R2, R3 and R4 in terms of "P" and "L"?
From my own understanding:
1. P = R3 + R4
2. Since the frame should stay static, the tilting force from P would result in R1 to be a downward force.
I did my own calculations but got confused, still had some doubts. Hope someone can help on this, thanks!
 https://files.engineering.com/getfile.aspx?folder=33b172c9-77fb-46b8-b388-4358ca9e91a5&file=Structural_Frame.png
In the absense of DL and LL forces, R1 should be downward, or have a magnitude of P x L2 / L1 with a minus sign. You can use a +ve or -ve sign to change the direction, too... [pipe]
What BAretired said, assuming the columns are equal size.
