wcfrobert
- May 24, 2017
- 19
Hello all.
I have a question regarding bottom integrity steel provision for two way slab design.
CSA 23.3 specifies a minimum integrity steel area at the four faces of a column (Asb = 2V / fy).
In the case of a garage roof with 1-m of soil on top, If I were to design per CSA, I would need around 5 to 6 20M bars through the column core; which is quite a significant amount. Can this steel be used to reduce the number of bottom bars in the column strips? It's interesting because then the middle strip bar spacing would be smaller than that of the column strip.
ACI doesn't have any formula for integrity steel and only mentions that at least two bottom bars have to extend into the column core with full tension lap. That's quite the difference. Thoughts?
