swearingen
- Feb 15, 2006
- 667
I'm looking for a pin-type element that is calibrated to resist a certain load, then shear. I expect the loads to be in the neighborhood of 10,000 lbs or so.
I have a threaded rod that is bracing a support holding up tubes that expand and contract due to high temperature. I don't want the expansion to break the wall I'm bracing against, and I want to be able to see that it has been overstressed.
Does anyone know of a commercially available item such as this? I can design it myself, but the margin of error will be quite a bit higher than a tested product.
-5^2 = -25 ;-)
-5^2 = -25 ;-)
