Grawschbags
Hi folks,
I'm new to the forum. I previously worked in the defence industry as a mechanical engineer. I have recently made the switch to a smaller engineering firm who deal with tanks and structures.
Now, my memories a bit rusty and I need a quick solution to a problem I haven't come across since my uni days. Hopefully you can help.
I am designing a structure that is to support a 60m^3 storage tank, that when full could weigh up to 90 tonnes.
This cylindrical tank is to be supported by 4 legs (with additional cross members) equally spaced around the tank diameter.
It has been proposed that the legs of the tank be made from 180X180X8mm square hollow section, mild steel.
The height of these legs will be roughly 4m tall, with the tank sitting on top.
The cross sectional area of the beams is 54.4cm^2, and the moment of inertia is 2661cm^4.
Could one of you kind people please confirm if these sections are man enough to do the job?
Thanks for your time/help.
G.
G.
