SteelPE
- Mar 9, 2006
- 2,759
Hopefully I can explain this properly.
I have a structural slab that is uptight to an existing building. Parallel to the building, I have a grade beam that is 5’-6” away. The slab is being designed as a one-way slab. The question I have relates to the fact that the existing building is set 45 degrees to my one-way slab reinforcing which makes the cantilever reinforcing 45 degrees to the one-way slab reinforcing.
How do you handle this moment with regards to the main one-way reinforcing in the slab? Is it a matter of SRSS (square root of the sum of the squares) or is it much more complicated that this (which I think it is)?
