HgTX
- Aug 3, 2004
- 3,722
I have a designer who wants stainless steel for corrosion protection & aesthetics, but assumed he could use typical carbon steel properties in the design. So he assumed yield strength of 50 ksi and ultimate tensile strength of 125 ksi.
I fear I may not be able to make this work.
These are rod & hanger assemblies for a bridge. Fatigue loading, some components welded, some machined. Outdoor exposure, but not to salt water and probably very little road salt, if any.
The bridge design specs say that the SS has to come from ASTM A 176, A 240, A 276, or A 666, or something that meets the chemical & mechanical requirements of something listed in one of those specs. Or "other published specifications that establish its properties and suitability and that it is subjected to analyses, tests, and other controls to the extent and in the manner prescribed by one of the listed specifications". Which I choose to interpret as "if I need to go elsewhere to make it work, so be it".
I am assuming we need some kind of austenitic SS, preferably 300 or 400 alloy group. 304 or 316 type would be best.
For starters, we need 1.75" threaded rod/bar.
Nothing in A 176 meets the strength requirements.
Nothing in A 240 meets both yield and ultimate strength requirements.
Nothing in A 666 meets the strength requirements unless I get into the cold-worked materials, but I think those are all just sheet, not plate or bar.
In A 276, I see:
XM-21 (S30452?), S30454, S31654, Condition B ("relatively severe cold work")
Are any of those available as 1.75" rod/bar? And threadable? (And available as melted & manufactured in the U.S.?)
But wait, there's more. That's for the threaded bar. There's also 1.5" and 1.75" plate that needs to be weldable, a pin with a 2.5" diameter head (needs to be machined down to 2" diameter where the head isn't), a clevis that needs to be machined from material originally at least 6.125" in diameter (not to be welded), and...rectangular tubing, 5"x4"x3/16", weldable. So far I can't find that rectangular SS structural (as opposed to ornamental) tubing even exists.
So...does any of this stuff exist? And would they be better off with a casting for the clevis?
Hg
Eng-Tips policies: faq731-376
In A 276, I see:
Hg
