I am currently designing a 19m x 6m x 3.7m(height) structural steel shed to cover outdoor chiller water pumps. I tried searching online for roof beams connection (for perpendicular beams on top of column) but could not find anything similar, my question is which of the two connection methods will be more stable, as in beams connected to the columns (bolted) or beams connected to each other on top of the column, in this simple structural steel frame. (note that there are no loads in the roof other than insulated corrugated sheets)
