I am the E.O.R. of a 3-story ordinary moment frame building and am in the process of reviewing shop dwgs.
The designer whom is no longer with the company designed the moment connections using shop & field welded top & bot. plate with an oversized round hole for 3/4" A325 bolts, the fabricator proposing to use 13/16" X 1-1/8" slotted holes for field connections, I am comfortable with the 13/16" over size slot, but the 1-1/8" in the direction longitudinal with the beam seems excessive. Any input on this will be greatly appreciated.
I have attached a sample shop dwg for visual. My question is, without reanalyzing the connection which was previously designed, most likely, over designed with a safety factor, is the 1-1/8" slot too much of a net area loss for a 3/4" bolted connection. In the attachment, the example is a 6 bolt linear connection, top &bottom shop welded plates to form the connection.
