Good afternoon all,
Please see the attached file for a reference.
We've recently had a string of projects where more and more client's are starting to request the use of these structural beam pipe supports rather than traditional pipe base ells/dummy leg supports. Their reasoning seems to be that the pipe dummy legs are failing inspections due to the 1/4" weep hole becoming plugged over time and trapping moisture inside. This of course is leading to internal corrosion of the support itself. The structural beam supports are their way of fixing that issue.
I'm curious if others are noticing a trend in this direction as well for pipe supports, or if these have just been a couple oddball client requests. As far back as I can remember, pipe dummy legs/base ells have always been pretty common practice in the piping world.
I'm wondering, if the 1/4" weep hole being plugged is the issue, couldn't a slightly larger hole be drilled, say 3/8" or 1/2", to help aid in that problem? Or could it be more of an issue of the inspections not being carried out routinely enough to prevent the weep holes from becoming clogged?
Thoughts? Oh, and all the projects have been B31.3 as well.
"Thinking is the hardest work there is, which is probably the reason why so few engage in it."
-Henry Ford
-Henry Ford
